I should have been doing other things today, but one gremlin needed dealing with as it was calling my name.  Also an opportunity arose, so it would be good to take care of that too.
Whilst boring holes yesterday and killing hole saws, I decided to do an easy one and add another bit of plumbing at the back. 92mm hole saw is supposed to be good for 90mm corrugated ducting. It’s not!! And the new hole saw didn’t like cutting the wooden floor.
So armed with a sharp half round file I thought I’d soon get the better of this. The hole laughed at me! Better weapons required. Industrial flexible shaft grinder with a 25mm spiral band. It’s an abrasive band mounted on a rubber holder. The grit is resin bonded. It didn’t take long to resize the hole. As I was under the main floor l cleaned and reshaped some steelwork that I had previously roughly cut with the plasma cutter.
Two Tee pieces joined with some ducting and I’m through the floor. I still have to make an adapter so that I can fit an air outlet to restrict the flow. I don’t want all the hot air heating the garage space. The other side will match, but that’s a job for another day.
So I hoped a more pleasant job.  Two eberspacher controllers to mount. I was hoping for some kind of symmetry, but I thought I’d better look first. Caught you!  There is a redundant handle under the moulding, there goes my symmetry.
Wiring can’t be hard?  Pins in plugs, no problem. Even locked in place. Now I wondered why I had been given some pins for the sockets?  The loom had incompatible connections on it!  Then the new connectors need a suitable crimping pliers that I did not have. Not nice, but I made do. Better still the water eberspacher still works.
Duct from L/H rear heater
From above heater
Eberspacher controls, Water and Air
