Time to get a few odd jobs out the way today
Firstly the roof. Fitted the Solar Panels a while back and cabled up, so got the loose cables running from panels to the cable entry box...
Finally got round to fitting the conduit on the side to give a cable a channel to tuck away into.
Getting one with a ready-fitted self-adhesive tape made the job nice & easy and just a few minutes work.
After this, moved inside to do another job that maybe been 6 months outstanding?
Bought a Lagun Table System and where I want to fit it I have a 13A socket in the way
It won't go to the left of the socket (which I would have preferred) as the fixings would not be contained within the seat base, so need to move the Socket. And removing the socket leaves a big hole so that essentially decides for me where it is going!
First things first - find a new place for the socket.
Made two holes in fact as decided to double up. Mounted vertically as the holes are as far to the left and top as they can be.
Needed to complete the socket fitting fully so I can see just where the Lagun mounting plate can go.
Wired up the two sockets. The way the AC wiring is done in the Autotrail is quite nice. WIth the Plug & Socket on the cables it makes it very simple to wire up the pair of sockets "on the bench" rather than having to bend over with your head under the seat to connect cables.
And then fitted in place. You will have noticed there was a slot hole between the upper and lower round holes. This makes it very easy to wire up and then put into place - the yellow interlink cable just slips through the slot.
You might spot that one socket is fitted normally and the other is rotated? That is deliberate as if they were both conventionally fitted the cable from a standard plug on the upper socket would foul the lower socket.
And the rear view with the cables reconnected.
Now onto the table mount ...
This was just a matter of fitting as far to the left as possible while leaving enough clearance for the socket trim cover and also making sure the big hole left by the socket is covered up.
Within the seat base there is the Backing Plate that gets supplied with the table kit to give extra support and strength
I needed to trim the top and the right side back to allow it to fit
So Mounting is complete!! yea - only 6 months after buying the kit!
I don't have a table top sorted for this yet. Because of the flexibility of the mount there are a lot of options and I'll probably watch a few Youtube videos for ideas on mount position (do a search for "Lagun Table" and you will see loads of videos).
I used a bit of ply around the likely size of the table top I want and mounted the table fitting to it. I offset the mount fairly significantly as this seems to get the most flexibility. I may well try different positions to see how I like them.
And a few pictures showing some positions ...
Side Table for the rear lounge. Handy for putting stuff on
Bit of a Desk for when sitting on the sofa?
Or maybe a desk when sitting in the cab?
Unsure what kind of tabletop to have at this stage apart from where to fit the mounting plate. Could go very traditional with a standard wood effect to match and blend in with the vans woodwork.
Or could go a bit more funky? I like this guys work and have seen it "in the flesh" also and is nice quality -
https://chippysworkshop.co.uk/
