Few little more tweaks to make the Cheyenne 'easier' to use and suit myself...
I had previously fitted a Victron BMV-712 Battery Monitor and just left in in the battery box for simplicity as I just wanted a quick way to be able to keep an eye on the battery bank, and did so via the phone or web.
I had always planned to move this into the living space to be able to just look directly and did this a few days ago
BMV-712 Installation by
David, on Flickr
I chose this location as it is easy to see by just dropping down a flap, and when that is closed up, the interior looks standard again
Flap Closed by
David, on Flickr
Unfortunately whilst doing this bit of work, I broke a glass lamp frontpiece for which spares have been obsolete and unobtainable for many years
. Came up with a replacement option however - more information on what I did is here:
Replacement Light Glass - An Option.
Something that I found a bit of a pain is the Overcab Bed Bedding when driving.
Now I specifically wanted an Overcab Bed, and it is a great place to keep all the bedding stuff out the way when not needed. But when the sliding base is pushed forward, to give the regular cab headroom, with the mattress (and new topper), plus duvet and pillows also pushed forward, there was a fair amount of bulk that wanted to drop back down.
What I did was simply to use a couple of straps to keep everything in place
Overcab Bedding - Secured by
David, on Flickr
Using these means I can keep the mattress half vertical rather than having to fold it all the way over, which is likely also better for the topper I would think? Then the duvet, etc are just between the mattress and the front of the overcab moulding and nicely out the way
Then to make it look a bit tidier, simply put a fleece over the mattress and tucked the bottom of the fleece into the bed base.
Overcab Bedding - "Fleeced" by
David, on Flickr
Minor little thing but this thread is about tweaks to make my Motorhome more enjoyable to use and this is one that has proved its worth even in the two days since doing this
On a similar theme of not really making a change, but improving the 'experience' was to replace the knobs on the Cooker.
I noticed one was a bit loose and when looking at the back where it pushes in there was a bit broken off. Looking at the other knobs, they all had similar problems, but the part that was broken off on the first was just cracked and would likely break at some time. I think this is basically just a heat/age related thing.
I decided to replace all the knobs (5 done, 1 still due to arrive) and the difference in the positivity when pushing them back on and using them was quite remarkable! Maybe an expense that was not essential but I think worth it personally.
You may be able to see in the photo below which one is still waiting to be replaced (It is one of the two that were actually broken in fact)
Spinflo Replacement Knobs by
David, on Flickr
