Well then Dave, do you have any plans to personalise the exterior?
It is possible I may add a few stickers or something, but not like I did with my Daktari VanWell then Dave, do you have any plans to personalise the exterior?
Has it escaped?I saw a daktari stickered motorhome in Arundel last summer.
Nooooooooo!I saw a daktari stickered motorhome in Arundel last summer.
Hey Phil,Looks like your new "flimsy" has enjoyed a cossetted, loved, life Dave, mind you I'm a bit worried about you going down the "flimsy" route as the next thing we will all be seeing are details about some kind of 'A' frame and a small car to tow behind
How would you charge phones and torches,all usb these days.USB sockets, never really thought of having them. Not got any 12 volt ones either. Very good lighting in Murky, so I’m not motorhoming in the dark ages.
I was watching TV via a Firestick and the electrics suddenly cut off around 10:30. Voltage went to 10.x V and the sargent system cuts out at that level.That’s what happened with mine Dave but much shorter life lol
I bought as an interim solution one of those extension blocks that plug into a 12V socket and give you 3 x 12V & 4 x USB Sockets. Handy little thing and seems to work well but of course all those connections are together and it makes me realize how much trailing leads around and not being able to use stuff where I want annoys me! When I built Clarence, I put 12V and USB sockets everywhere. And I mean literally everywhere! Got them in all 4 corners of the bed; by the end of the kitchen higher up; opposite side where we sit but lower down; and in the cab area.
Seemed like overkill in a way at the time, but now I know it was the right thing to do as when I want to plug something in, I just do it without thinking about it .
Something to put on the To Do list. (I doubt if there is any MH on the market which would be right for me in that specific way, but it should be such a simple change, no biggie to sort out )
Recharging with the Victron in Recon mode and since the batteries have flagged as being at 100% (charge put back + efficiency factor = charge out since last 100% reset), they have accepted an additional 26Ah and are still charging at 7A in at the moment, so I think I will be able to get a handy amount of charge capacity recoveredOK ... I like a little graph so here we go ....
Upto 15:20, parked up and voltage rather low!
15:20 to 15:35 was the engine running and the 'split-charge' system kicking (limping?) in with 10Amps of charge.
16:40 onwards is the Victron IP22 20A Mains Charger in recondition mode - voltage is creeping up (currently at 13.0V) and a pretty constant 20Amps whilst in bulk mode.
I thought the Sargents split-charge system (think it is just a relay controlled by the D+ signal) would have been better than just 10A? But the connection does only have a 20A fuse, so would be very unlikely to be better than 15A anyway.
No Fear though, a better one is on the cards
