Doodles
Thought i should move the thread here as will be updating with pics of progress.Should have some soon as main part of L shaped bed/sofa finished so will be going in later.
Fine looking van, going to make a great camper.
Just an idea, but I weighed a lot of materials, or used weights quoted on builders merchant receipts, just helps a bit to keep a rough idea as you go along. Well it did help until I lost the bit of paper I was keeping notes on. lol
So long part of bed/sofa in it will make an L shape along left side of van over wheel arch.
WARNING!!! do not go cutting through heaters inside your van willy nilly i just did thinking the copper pipes where for air but no it was fluid and started pouring out but sorted now re-routed it back in again but wont be getting switched on ever again
Will, just wondering, I know you will have thought about it, but are you Ok with blocking of rear door entry to van with bed settee?
That's a good sturdy frame...will that make up part of the bed?
could you not make a center piece that slide in to fit across the rear doors to give you a walk through so just slide out in summer and turn round to give you a ushape looking out through the rear doors
Hi Will.
I see you have changed your floor plan already...
What happened to the rear wet room?????:banana::cool1:
