Found something interesting in my Fridge+Inverter Setup which I thought worth sharing on this thread :idea-007:
I've been running the Victron Inverter in "ON" mode as it needs at least 15W to 'wake' it when in Eco Mode and on my testing I didn't think that the way the fridge started up would kick the inverter into life (there are some other non-fridge reasons why I left in ON, but will talk about them at the end).
I changed some communication wiring last night and now instead of using Bluetooth and an App to monitor/control the Inverter, I can use the Victron VRM Portal via the Raspberry Pi. To test that change, I decided to switch the fridge to ECO mode and have a play and that is how I discovered this new info :cool1:
So this graph shows how the power consumption changes between ON Mode and ECO Mode
On-vs-Eco by
David, on Flickr
If you check out the power consumption
between the peaks, in ON mode, it is around 22W and in ECO mode it is just 9W - so that is a difference of 13W
* - or around 1Ah for 2/3rds of the time.
That equates to around a 16Ah saving over a 24 hour period. That 16Ah/Day
* could be significant in some setups and even in my own with a decent sized battery and solar array it could be a useful saving over the wintertime
So my initial assumption that the ECO mode was not any use with a Compressor Fridge looks like it was not quite right :rolleyes2:
Now something that is specific to MY setup which means ECO is not actually the best setting necessarily are these:
I have an AC-Powered Network Router and Wi-Fi Booster. So when the Inverter goes off, the Network goes down! The Raspberry Pi actually automatically falls back to the built-in Wi-Fi linked to the Mi-Fi Dongle so that carries on communicating, but other devices (Laptop/Tablets/Amazon Echo/Fire TV/Now TV) will not.
*note that the 13W saving from ON to ECO also includes the fact the Router and Wi-Fi Booster are no longer powered up either, so it is NOT a 13W Inverter Overhead).
I can see myself switching the inverter to ECO mode while the van is parked up not being used to minimize power use, and then switching to ON mode once I have setup camp so I can use the extra AC-powered facilities easily.
An curious aside is the visibility of the In-Rush Power Spikes now.
The Victron system is setup to sample/snapshot the data every minute. The in-Rush happens for just a couple of seconds each time the compressor kicks in, which is typically twice an hour. So only occasionally does the sample time co-incide with the in-rush event and so rarely appears on the graph.
Now I have connected the Inverter direct to the Pi
**(running Victron GX software), the In-Rush seems to appear just about everytime the fridge starts up. It won't change the
actual power consumed, but it might change the
calculation of power used. (the Victron system might see a spike of say 300W and calculate that as being present for the full 1 minute sample period but it only lasts a few seconds).
**This spike 'visibility' could also be due to being in ECO mode as well? I am doing a test right now to check that and will update this part accordingly when I know
If this spike
visibility IS much more common when in ECO mode, the Victron system could even report in the overview chart that I am using more power in ECO mode than I am in ON mode.
You know what they say .... Lies, Damn Lies and Statistics .....
