xsilvergs
Well it is a saving
One of the unknowns is the impact on the unit of keep changing energy sources? Each time you ignite the gas on a burner, I understand something 'burns away'? miniscule effect maybe but it all adds up over time, so could igniting the gas on an hourly basis eat into the operational life of a gas appliance to any significant degree?
I really don't know but I am slightly wary about having the fridge not seeing a 'proper' AC supply when switched to it (i.e. when inverter is in ECO/AES mode) even though there are no apparent issues. I am a lot more wary about having the fridge restarted on Gas on such a frequent basis.
Personally, and on no basis other then my own feelings, I wouldn't set up the Stop/Start parameters so tightly
Regards reigniting:- I'm not using ECO mode. If the battery SoC is >=76% the igniter does not spark and it goes straight to 230V electric. Once the battery discharges to 75% the fridge switches to gas and the igniter does its thing as it would if just on gas. The fridge is unlikely to switch back to 230V in this ON cycle.
I don't think the gas would ever be ignited more than once in one ON cycle. I will monitor it and broaden the 1% gap if required but will be surprised if it needs it.
