		Only got one sensor reading available currently, so I thought I would just swap it over this afternoon from Icebox to Fridge to double-check it (the sensor) is still ok, as the cycling was so unexpected (to me, anyway).change of subject a little ....
I was working on configuring the Multiplus to work with Lithium and used the Fridge as a way to fool it into seeing a lower Battery Temp for testing purposes (sensor put into icebox in fridge). This exposed something quite intriging on the Inventor Fridge ...
This is what I usually record with the a Temp Sensor in the Fridge section of the Inventor Fridge. Typical pattern is the temp fluctuates very little (it is excellent in that respect in fact)
But today I put the battery sensor in the Icebox as I said (note that this is an identical sensor, but connected to the MP, not the Venus GX)
This is what the Icebox is doing when the Fridge is doing its normal power duty cycle
The Freezer seems to go down to -15C rapidly as soon as the compressor comes on, but as soon as it goes off, the temp goes up again nearly as fast. It actually looks like the Fridge Compressor duty cycle is linked to the freezer temp, kicking on when it is at OC, and off when down to about 15C?
Now the Info for the Fridge does say that the Icebox is not designed to be a freezer, but I would have expected much less of a range variation!
(PS. For info, in the chart above, the fridge is running on mains, not inverter)
Right now I can't do it, but next week I will put a sensor in Fridge AND in Icebox and map the pattern. Also today is a pretty hot day and that could have affected how it works somewhat.
Took the sensor out the Icebox, left it out for a short while to show ambient and then put it in the fridge....
So back to what is expected with a slight raise when fridge is off. The Icebox is definately only useful for icecubes and icepops. Stuff that doesn't matter if it starts to defrost and then refreezes.
