Entertaining video, he has a good delivery style, if I was a patreon I would ask him and you maybe able to show it but I cant help but think that as the Lithium starts to drop below 13.2 ie towards the end of its capacity and you still have load requirements such that it contimues to drop that the Lead Acid is going to start to put large amounts of its capacity into charging the lithium, I dont see how you can stop that and I'm thinking it will be significant current although the more current the lithium wants the more the voltage will drop so maybe it wont be so bad.
For him to go 5 days without sun his bank of lead acid must be large, he doesnt really discuss what he has so I wonder how much he supplements with Lithium.
Interested to see some current graphs of flat lithium and fully charged AGMs even if they are at the same voltage.
I'm yet to be convinced but only because I dont know how the relationship between the Lithium and the lead acids will work with a fully discharged lithium.
Hi Pete.
He does actually say how much Lead he has .... 1500Ah. Quite a bit there
but simply the less you have, the less time you can go between charges of course.
It does take a few mental to's and fro's to really get your head round the idea but when I saw his video it really did crystallize the thoughts I had already along this line and convinced me it was a sound theory.
In terms of the Lead putting large amounts of its capacity in the lithium, it is very much as SquirrelCook says "I think it’s all based on voltage differentials e.g. a lower voltage battery will not charge a higher voltage one" as we would all agree I think, and why this concept works is that the 'natural' voltage of a Lead battery is so much lower than a Lithium battery - which is why the Lithium Battery will neither take a lot of energy out the LEAD, or fully discharge.
It is a little early to present this graph as it does not cover the full discharge-charge cycle, but I think it is interesting to see ...
This is the data from 17:00 yesterday until 10:00 this morning. All batteries started fully charged (there is some use in place already as I forgot to change a setting on the new BMV but it doesn't change the basic pattern shown).
Lead Data is red, Lithium Data is Green.
The Left Y Axis is in AHs and the Bars are AHs used (stacked to show the total for the whole bank) and are cumulative values as time elapses.
The Right Y Axis is in Amps and the Lines are Amps out/in for each Battery (-ve values is current drawn OUT of the battery)
OK, to explain as I read the data....
At the start of the time, you can see that pretty well only the LiFePO4 battery (green) is doing anything. The green bar keeps growing and PbC AGM bar (red) is pretty static.
This is the case for the first 9 hours or so and then - as the voltage of the Lithium battery drops as it gets to around 80% DoD (80Ah), the Lead batteries essentially take over. I guess the quiescent point when that happens is where the two current lines cross over?
From that point, the LiFePO4 battery starts to hover at around the 85% DoD mark - when there is a higher demand, it contributes a bit, and when the demand goes, it takes back some power from the Lead bank to get back to what would seem to be its 'settle' point
This next graph illustrates that - drilling down into a specific hour you can see what the current for each battery looks like
At the start of that hour, there is a power demand (the new Purple line is the current demanded from the battery bank as a whole) that is met from both the Lead AND Lithium batteries. But when that higher demand goes away around 27 minutes past the hour, the green-dotted line goes below the 0A line - in other words, it is taking power from the Lead bank - but only enough to make up for what it gave up the 30 minutes before to keep at around 85% DoD rather than to actually recharge.
I see this is a function of the voltage differences between the technologies and is the core reason why this kind of Hyrid setup can work.
Very shortly the overall SOC will hit 60% which means the intermittant high demand of the fridge will go as it disconnects from the AC, and the overall setup goes into one of Charging rather than Discharging - and so we will see how the solar harvesting gets distributed to the two different battery technologies ....
