I mentioned on my other general Motorhome Tweaking thread about having a look at 'Home Assistant'. I thought I would add some screenshots of the early configuration of Home Assistant as it relates to the Electrics setup and particularly the Hybrid Battery Bank I have setup in the Motorhome.
A wee recap ... so the Hybrid Battery is basically a Lead Acid Battery Bank, and a Lithium Battery Bank, connected in Parallel. There is a relay between the Lead +ve and the Lithium +ve that allows optimal charging of both technologies, but when the batteries are under load, they operate together and the relay is essentially closed.
Lead Acid and Lithium batteries operate in quite a different way, and it is that difference that makes their use in a paralleled Hybrid Bank so effective in fact, but it is useful to keep an eye on the setup still for someone like myself who is checking out various configurations, as the different operating characteristics means they stay optimal in different operational 'windows' when it comes to voltage ranges, discharge limits and current ranges.
A quick overview to check the setup will be useful and something that Victrons VRM cannot currently provide (although some customisation is due early next year). I did setup some gauges with Node-Red, but that product frankly I find annoying and frustrating.
So enter left stage is Home Assistant. This dashboard focus as discussed is very much on the Battery aspect.
This screenshot is with the system under net load - so say being off-grid, maybe not much solar.
for the CURRENT graphs, Green would be an incoming current i.e. Charge, as that is the optimum situation. Amber is a current draw within ideal limits and Red is a higher current than you really want.
For the other battery graphs, an arrow in the Green means the value (SOC, Voltage, AHs) is within good operating range, Amber is your warning condition, letting you know something is getting close to the desired limit, and Red is the point where you may need to consider taking action.
And the positioning of the bands depends on the battery type. So for example, if you take the SOC (State Of Charge) graphs, the Lithium Green band is a lot larger than the Lead Green band, reflecting the fact that Lithium can be taken a lot lower than Lead without detriment. (The Hybrid Green bank is a mathematical calculation of the Lead and Lithium parameters).
So the view above tells us that right now everything is looking good, with all the needles within the Green, except for the Current - reminding us that the battery bank IS under discharge conditions, so a gentle warning there.
If we put the off-grid system under a bit of a heavish load. you can get an nice visual effect of how the components of the Hybrids battery work together.
The load of over 1kW AC, equating to 128A load from the battery is shared between the Lithium and Lead Banks. Although the Lithium is a 1/3rd the capacity of the Lead, it still takes over half the current. The CURRENT graphs show the needles in the Red, which is not surprising as it is quite a current to deliver, but still doable (hence why it is not actually 'off the scale'). The VOLTAGE graphs are also sneaking down due to the typical voltage sag of a heavy load that both Lead and, to a lesser extent, Lithium suffer.
The AC LOAD shows how much power is being drawn and the GRID SUPPLY shows 0 W, so again confirms this is all being supplied by the battery.
This dash shows overall high-demand situation which if left to continue would drain the batteries, but is ok in the short term (in this case running a microwave).
And finally a view with EHU active and how that affects the graph needles.
Voltages up of course as the charger is on. The right hand side shows the power coming into the Motorhome, and the power going to AC and DC systems, with the logical difference being a charge into the batteries! The CURRENT graphs show the needles into the Green now with positive current, and you can see clearly the current is taken by the different banks.... The Lithium provides the majority of the power whilst its SOC is in the Green, and it takes most of the charge input when available as well until it is back to 100%.
All these graphs are certainly not needed to run a Hybrid Bank such as I have, but it is, I think, a very nice dashboard to be able to glance at to check what is happening and all is ok. I could also create warning alarms for say a battery SOC is below a certain value and maybe I will do so, but that would be just a bit of icing.
