Solar Panel Questions
I have a couple of Solar panel questions @wildebus and others ?
New van has a small Solar panel on her and a rather rubbish looking charge controller, with a Lamp plugged into the Streetlight port and for what purpose I have no idea. Pictures to follow.
  • with little knowledge of the Solar Panel that is on the Van, how can I work out what the output of the Solar panel is ?
  • has anyone used any flexible solar panels and are there any that are better than others ?
Thanks in Advance
Robert
If you have a multimeter set it on Amps ( usually the centre lead plug is the common and the plug either side of common is volts/ohms or Amps depending on where you plug into) max amps on most cheap multi meters is 10amps which is plenty for average single solar panel fitted to a vehicle. Disconnect the pos and neg leads coming from the solar panel at the controller connect the multimeter leads to the solar panel leads for a short period ( Enough time for the amps to settle on the display) if this is done on a bright sunny day it will give you the max amp output that your particular panel will supply ( Probablyin the 5-8 amps range), then change the multimeter leads to volts and measure voltage output which again on a sunny day should be in the 21-27 volts DC range this at least will show you that it is supplying a usable output. Phil
  • Thank You
Thanks in Advance
Robert
Is this panel a flexible one? If so checking specs by lifting panel will probably be tricky but that - if possible - is the way.
Connecting up the Victron controller to it and then leaving it for the day will tell you from the data a good indication of the Voc.
I would just physically measure it and that is a good indication. Panels tend to be the same rating per square metre, so a 100W panel tends to have a working area twice that of a 50W.
Then determine if mono or poly. Mono panels have distinct centre bits between the cells; poly tend to appear more of a single large area with lines down them. A poly panel is usually around 10-15% lower in capacity for a given size.
Flexible solar panels .... They vary tremendously in quality, much more than glass ones. For a reliable flexible panel, budget at least 2x the cost/watt compared to a glass panel. Assuming you are talking about updating the panels on the new Sprinter I would strongly recommend you stick with glass.
I want to avoid having to drill holes in the roof and there are no roof bars.
So for off-grid I think the best approach would be, as you say above, maybe get someone to weld a simple rack onto the Van, create a double array of glass panels, maybe 2 x 310W which are on a piece of angle and can be tilted.
Costs from the Top of my head:
Rack: £500
Panels: £260
Kit for making tiltable: £100
Cables and ancillary £30
TOTAL IRO £900 and a lot fo work with output at 620W
Alternative, less work but not such great output in power as the above,
3 x Good Flexible Solar panels like www.bimblesolar.com/solar/small-panels/150w-semi-flexible
Panels £600
Glue £20
TOTAL IRO £650 and less work but output MAX at 450W
Thoughts ?
If I had a van I would definitely be looking at a roof rack/rail system. The way you can fix panels and move if necessary is a bonus. Can you not get clamp on racks still like I see on work vans for yours?
Only need one hole for gland box entry that way and may make it easier if you want to go for tilting panels later on.
Well, in your financial comparision, take off the £100 for the tilting kit on option 1 as you are not having that feature in option 2 (comparing oranges and apples otherwise).
Next, £500 for rack? what access do you have to the underside of the roof? if you can access it then you could do similar to the approach I took - Add your own roof rails ...
IMG_20170820_105556
by David, on Flickr
Doing this will cost around £100 on your van
And you can get fixing kits, like shown in this picture ...
Entry Box routing and Panel Mount
by David, on Flickr
This approach also encompasses the point made by Neil ...
The reason I went for what I did was precisely to allow flexibility of fitting. My panels are fitted flat, but I could easily change to a tilting system, or move panels around whenever I want.
These are in place but I can move them in minutes
400W in Place
by David, on Flickr
There are no factory rail systems for the Sprinter Mk 1 (T1N) model, and Roof racks would need holes drilled anyway unless gutter-mounted - and using those would stop the use of the awning (gutters are low on these age vans (the transit jumbo is just the same).
I would do some measurements as well. Do you think a pair of 310W panels will fit on top of your MWB Sprinter? I worked out I could just squeeze in 600W (6 x 100W) on my LWB from front to back if I filled the roof with panels and my van is of course longer than yours - by just shy of a metre.
And as the rear end and front end are the same, that means you have around 1.6 square metres less roof space to accomodate panels, plus I am guessing you have at least one roof vent to have to work around?
Some numbers on this thread ... https://motorhomebuilder.com/threads/van-size-comparisons-the-germans.66426/
I would have a look at the sprinter-source forum and get some ideas there as well.
Your system was exactly what I was thinking of Dave. A raised rack may be better if you have a few skylights as you could fit above them but obviously restrict opening. If only one roof vent or more close together your system is a no braine to me.
Can you get raised stand offs for your slides anyway Dave, something that would allow say six inch mount above roof to clear vents?
edit: I hate auto correct and predictive text at times lol
I could do that very easily with some aluminium C Channel - along the lines of what Phil Admin as done. I was toying with just that in order to add another panel at a jaunty angle over the MaxxAir fan but decided against it and looking at other quirky ways to add capacity ;)
All very interesting @wildebus and @Nabsim THANKS
I am toying with ideas at present as Van is still in it's infancy and some issues to tackle first anyway, not in any order:
  1. Slide Door not opening from inside, just found out this AM
  2. STILL smells of Dog
  3. Pre-heat light stays on whilst driving on dash
  • Thank You
oliviamas
Free Member
We installed a 300 Watt solar panels system in our van and we love it! It makes living in a van much more comfortable, especially since we're also traveling in the caravan!
