Byronic
An interesting thread and a bit spooky as I often wonder why they are not widely used in homes as well. If I could fit one at home, in the kitchen, I would and might do it when we do a revamp.
They went out of favour mainly because modern demands meant that hot water was often required simultaneously at several places and even the biggest instantaneous heaters called multipionts could only supply 3 taps or so at once and at a reduced flow rate. People weren't keen to have possibly 3 of these heaters to obviate that prob. they don't exactly look fashionable.
Also their efficiency isn't the best, a lot of heat goes up the flue, and if you constantly turn them of and on you are also having to reheat the metal water tube. additionally the water has to flow for a while before its at the predetermined heat also the rubber diaphragm which controls gas flow hardens over time so they're not maintenance free.
Not trying to put you off but you did pose the question.
But if you need hot water remote from the main source they could be an answer.
In a motorhome I would say they have their place especially for the shower and maybe washing up with a kettle for everything else, but each to their own.
In hotels the hot water supply may be 100 meters from some of the taps, the hot water has to be circulated in a constantlly pumped loop otherwise a tap user would have to draw perhaps 50 litres of water every time he wanted hot water........ now that really would be a waste.
