Still at £25 or above looking around interweb252i Architectural
Found these:-
Which might be alright for the semi flexible or flexible panels that have the grommet holes in them but wary of going through the roof with a rivet gun.
So
Like what sort of Alloy Brackets please ?
They are generically known as "Z Brackets" or "Renogy Z Brackets".This type LINK. Lots of other suppliers
Thanks, think it may be a big job to go down the full solar route and possibly be better to look at the rails idea as you have suggested before.Something to take note of, Robert ... the Sprinter roof has quite a curve on it and if you have a panel across from edge to edge, you need to raise the ends up a fair bit in order to clear the centre of the roof.
I have considered that as well, my concern would be security though. As a test I have ordered one of these for the Dash and / or outside to see what sort of output I get with the Merc out and aboutWhile I have nothing against generators and use one every couple of days this time of year you may still be able to meet your needs with solar. I have seen a lot of fulltime folks in vans with just a loose solar panel and leads going to controller/battery bank
