A generator certainly is a handy thing to have if the need demands it.It could just about cope with the fridge kicking in, but sounded heavily loaded. That said it runs for about 6 hours on very little fuel so good for emergencies.
Finally I returned home to find Murky's leisure batteries fully charged, funny what a little sun will do.
This morning I switched on the inverter and fired up 2 of the 7.5 amp chargers to bring up the engine start batteries.
20 amps drain from the two chargers, not the most efficient.
This one of the down side of the bigger mercs, their is a current drain I've never been able to track down. They provide an isolation switch for the batteries, but then the alarm or powered doors don't work. Odd characteristics, it draws more current in winter than it does in summer. Also when connecting the supply there is a current serge just like a big capacitor is in the circuit somewhere?
You don't have an engine preheater do you? I had one in my VW T5 that apparently kicked on under 10c. Went wrong and something in it ran all the time even with ignition off. Not good for the battery that was for sure!
In my VW LT (like a Sprinter Mk1), I have the tacho constantly going which is no doubt some kind of draw. That plus the door step lights that are on whenever the doors are open (so if I leave the slider open, the starter battery is getting used).
As it happens I am just prepping for another test on this area I've disconnected the bi-directional Cyrix-CT VSR and am keeping an eye on how the Starter Battery voltage is decaying.
A very smooth decline there (the Battery is new since around July this year and is a fairly nice unit). because it is so smooth it is possible to clearly specific events but there is certainly a constant power draw visible.
In the next day or so I will be fitting a prototype programmable Starter battery trickle charger (similar to a Battery Master, but with more features and capability) to see how that manages the starter.
