Lord Lucan
If no, or poor solar, which hookup battery charger is good to use?
I am looking at a Victron Charger for a Van build, one that could report on 240V Consumed and Power Used in that process.If no, or poor solar, which hookup battery charger is good to use?
Interesting comment. not something I have thought of actually. clocks going back would actually mean today is 25 hours long so a longer day. but as the extra hour is in darkness, does it actually matter? intriging.... So from TODAY 27/10/2019 Yield will be less all over UK due to the clocks going back so would be interested to see Today's Yield Vs Yesterday's longer Day yield
There are lots of options of course.If no, or poor solar, which hookup battery charger is good to use?
Rpbert, Victrons Mains chargers are very good and tick all the boxes in the list in the reply to Lord Lucan, but .... they won't do what you want in terms of reporting UNLESS you get one of the new IP43 models (which is, at least at the moment, rather pricey!). The IP22, IP65 and IP67 models have no VE.Direct Port so will not talk to the Venus OS system. You can of course get 'moment in time' data via bluetooth on all of those products thoughI am looking at a Victron Charger for a Van build, one that could report on 240V Consumed and Power Used in that process.
I am quite Taken with the Victron Multiplus units but sadly they are likely out of budget.
Would it be OK to get a Larger one if the battery bank were to be upgraded in the future ?Capacity. Get one suited to your battery. So for a 125Ah battery, something along the lines of a 20A or so would be sufficient. There is a general rule of thumb that a charge rate should around 10-20% of the battery capacity, so a 125Ah battery would typically want no more than a 12.5A-25A charger.
I would not rely on External Power or EHU but rather have decent Solar as the primary power source; split charge relay as secondary power source; and then EHU as an optional third Power Source. EHU would be used at home when parked for top up in Winter and to send 240V to a few sockets in the Van for works etc. Make sense ?One thing I've thought about with big chargers, is the power required to run them. Ok the multiplus can limit the loading on an external power source, but it can still be a lot of amps if you rely on external charging. I remember using 3 7.5amp chargers with a 1kva silent smart generator. Poor thing reved it's nuts off, and was not silent coping with that loading.
Firstly, I assume that is just a link to the product and you don't intend buying at that price?! (Victron have a New-Style Multiplus in the 500-1600VA range size which are much more keenly priced - Have a look here at info on the new range.Would it be OK to get a Larger one if the battery bank were to be upgraded in the future ?
So as it stands 230AH = 23Amp to 46AMP
Future possibly 800AH = 80Ampt to 160Amp
So if I got https://www.cclcomponents.com/victr...2v-1600va-70a-16-230v-ve-bus-inverter-charger
That would probably do the Job I would think
I am surprised it had such an effect there - are you talking 7.5A@12V? 3 x 12V 7.5A Chargers only adds up around 2.5A so should be well within what a 1kVA Generator could provide? Sure, not silent, but better a bit more noise and power but for a shorter time?One thing I've thought about with big chargers, is the power required to run them. Ok the multiplus can limit the loading on an external power source, but it can still be a lot of amps if you rely on external charging. I remember using 3 7.5amp chargers with a 1kva silent smart generator. Poor thing reved it's nuts off, and was not silent coping with that loading.
In summer I don't plug in as solar generally is enough when out and about or as long as I move out the shade sometimes when parked at home. Outside of summer I either just leave plugged in when at home or plug in once a week to recharge (or if I go down to say 70% or so)I would not rely on External Power or EHU but rather have decent Solar as the primary power source; split charge relay as secondary power source; and then EHU as an optional third Power Source. EHU would be used at home when parked for top up in Winter and to send 240V to a few sockets in the Van for works etc. Make sense ?
Just PM'd you LOLNo Probs. That was a link to my own site as I knew there was a write up there. Remember other sites are available.
I got my money back for that small controller. TBH I think it is a nice unit and good value for money for a PWM (but it was described as MPPT!)Thank you so much wildebus for all the proper info,i shall soon as pos fit my mppt regulator,mind you the we so called one you tested same as mine is keeping the battery up,but im thinking that once the fridge goes in the mppt unit will by miles use and make a better job of keeping batts up and faster to,cheers.
It could just about cope with the fridge kicking in, but sounded heavily loaded. That said it runs for about 6 hours on very little fuel so good for emergencies.I am surprised it had such an effect there - are you talking 7.5A@12V? 3 x 12V 7.5A Chargers only adds up around 2.5A so should be well within what a 1kVA Generator could provide
Personally, if your thinking about a charger just for storage I'd be tempted by one of those smaller Victron ones. Say around 15amps. It's not like you'll be charging in a hurry to go somewhere. Once it's done it's business it goes into storage mode.Make sense ?
Did you both Bolt through the roof panelling to fix the long bars ? If Bolting through the roof how do you ensure fully sealed holes from water ingress when there is likely going to be some movement and force exerted on panels through driving momentum etc
