Ok, so back on subject.
The testing with the solar panels has not really made much impact due to the combination of bad time of year for testing plus lots of restrictions such as house and trees.
Harvesting has dropped down to well below 1W per panel now so that is it for the day. To eliminate Location and Panel difference, I have swapped over the cables and will leave running for a second day.
Total harvest from 200W of PV Panel today .... 73Wh
- That works out to be just 6Ah of energy back into the battery.
Will wait until end of play tomorrow to evaluate the results and do the comparisons.
Conclusions after two days of testing using Solar Panels?
Don't bother doing solar controller comparisons with PV panels in Late October in Scotland!
I see that the performance of the MPPT controller looks to be better than the PWM (as to be expected), but in reality, it is hard to judge how much a different it makes as the solar performance is so poor, even a 30% improvement over sod-all will still be sod all.
As mentioned, Day 1 got 73Wh of energy in total with the two panels. Day 2 went down to 29Wh of Harvest.
I think I said earlier on this thread, or maybe elsewhere, that a drive to the shops will get you more power in? Well, I thought I would show a graph to show what I mean ... Below is a snapshot of the middle half of the day (6AM to 6PM)
That vertical line , labeled 09:15 - 09:24? well in that 9 minutes I put more Wh into my batteries then the 200W of Solar Panels contributed for the entire day on the controller test.
Unless you have a very clear and unobstructed line of sight to the sun, solar in the winter is extremely limited and it really doesn't matter how good your solar controller is, you will still get virtually nothing and idling your engine for 5 minutes will get you what a 100W panel may contribute in an entire day.
Now no doubt there are people who will say they harvest loads all year round, but this is my own conclusion from my testing in my location, with trees that obtruct the low sun, lots of cloud and a fairly short solar day - think it is called "real life in the north of the UK"
Out of curiosity, I have put the Victron MPPT back on a panel and will see that that does for the day. It looks a fairly similar overcast day.
Here is a chart showing the kind of difference in Solar Energy between yesterday and a day in Mid-August
Less then 10% of the Solar Radiation is being received!
Another Conclusion?
Don't rely on Solar Panels in Scotland in the Wintertime. (I already knew this one
I'll probably do another controller test, but if at home will have to wait until Spring next year due to my test environment as the low solar radiation means no useful data is really getting obtained and any results are pretty irrelevant.
