Four days waiting for the results
Not seen any effect on mine, but my van does spend a lot more time on the Driveways than yours I suspectOn a slight tangent....
Did we talk about domestic fridges and needing to let them settle after travelling?
The instructions often say let sit for x hours before plugging in.
I have a hunch mine goes all screwy after a journey if it runs too soon after stopping or during driving.
Don't unplug it!The instructions often say let sit for x hours before plugging in.
Don't unplug it!
Bring on the Yodeller ...........If it was my fridge alone running off that battery it would last I think approx 60 hours.
I do.Just a thought Dave, do you know what temperature your fridge is set at?
I am quite a bit different in that respect I like it nice and warm and will have the heating on a fair bit - and unless it is a very warm night I will often have the electric blanket running for quite a bit of time over nightMy usage is fairly constant Dave, doesn’t matter if it’s summer or winter, hot or cold, fridge that is or seems to be anyway. Overall daily use can vary a bit, if we have some bad weather and I stay in with heating on it goes up a bit but not that much as I usually don’t have heating in at night or if I do I turn it down to 10 degrees.
Actually no. My point on the voltage ...I wouldn’t expect it to be any different amps used, should be the same for any battery type shouldn’t it? Just how long you can run it without damaging your battery’s.
of course while twice the amount of lead acid will give you a similar capacity it will need twice the space with 4 times the weight. My two 100ah Lifepo4 come in at the same weight as a single Bosch/Varta 90ah PowerFrame they replaced.
of course much more expensive and you need suitable cable and ancillary items. Nothing is simple huh
David, interesting results, I'm not surprised but most of your results.Decided to run the same test one after the other to get a "in-service" comparision of Lithium versus Lead batteries.
The actual battery power used was near enough identical when the non-laboratory environment was taken into account, but that is just part of the story. What about the other aspects that should be considered?
Power Capacity & Delivery.
Well, if you size the batteries appropriately (i.e. get a Lead Acid twice the Ah capacity of the Lithium) then the usable capacity is pretty well the same for most people. Where Lithium batteries definately have an edge is the way the voltage stays at a higher more consistant level.
Applying Ohms Law, where P = IV, or Power (W) = Current (A) x Voltage (V), the lower the voltage, the greater the current needs to be to deliver the same power.
So as a Lead Acid battery starts to drop in charge, the voltage reduces and when the same power is demanded (e.g. from a fridge), the current is higher and the power drawn is higher. This means that a lead acid batteries efficiency is constantly (albeit slowly) reduces immediately from the point it gets used, even from100% full, whereas a Lithium batteries efficiency reduction is not really noticable until you get to a pretty low SOC.
NOTE: I have seen a few claims on Battery Specs and quite a few YouTubers saying that Lithium Batteries are perfect with inverters because the voltage doesn't drop. Yes, they are good - and often better - with Inverters, but NO, the voltage still drops under load.
A couple of graphs to illustrate this difference (note the differences in scale when comparing) ...
The LiFePO4 Battery in the last half of the Fridge test
You can see how the voltage dips as the current increases, but generally the voltage is sitting in excess of 13V even when the battery is at this stage getting below 50% SOC
The same time period for the Lead Acid
In the same time period the voltage has dropped pretty well twice as much from start to end, and is noticably lower (13.2V vs 12.70, and 13.1V vs 12.5V), so each time the fridge comes on, calling for its 50W of power or whatever, the current draw will be higher on the Lead Acid and so the power taken out the battery will be greater.
Recharging
Once you have the power consumed, you need to replenish of course. So let's compare the two....
Couple of comments first.
Lithium - I set the charger to the recommended limits by Relion - so 50A maximum for the RB100 (a C2 charge rate)
Lead Acid - Usually there is a maximum charge limit of around 25% for a good AGM Lead Acid Battery, and often lower. My Lead Acid Batteries are Lead Carbon AGM and have no charge current limitation so I set the charger to its maximum (120A) as I was also interested in how my own specific setup would compare with the Lithium, but most Lead Acid Batteries will not (and should not) charge at this level!
First I took the Lithium to 100% DOD - to the point where its internal BMS shut it down ... 0 Volts out; Plus I took the Lead Acid battery down below 50% (actually ended up being 45% SOC). So each battery needed 100Ah+ put back into it.
The question is how long would it take to get the batteries back up to 100% charge, as that is the critical thing when using Lesiure Batteries.
Plugging in the RB100 LiFePO4 Lithium first.
Pretty well two hours of bulk charging at around 48 Amps into the battery got it near enough full (the charger was set to 50A limit, so the 48A represents the efficiency loss of 4% in the charger - I guess I could have set it at 53A limit so it would be 50A at the battery).
So 96Ah in the first 2 hours and the remaining 45 minutes or so was the small 10% or so top up (the RB100 100Ah battery actually gave 104.2Ah at the point it switched off)
The Lead Acid profile was quite a bit different (showing the SOC and the Voltage/Current info here)
The 215Ah PbC (Lead Carbon AGM Battery) took in up to 110Ah and that started to drop quite soon, but it is still a high current coming in. The charger switched to float prematurely (the Multiplus Charger tends to do this with these batteries when they are getting a charge from a lowish SOC, and I have not sussed out why yet), but did a quick reprogram to get the voltage back up to carry on as required.
Interestingly this lead acid battery accepted in the two hours near enough the same amount of Ahs back into the battery as the Lithium battery did, which was a bit of a surprise TBH, but to finish the job took longer (as as you can see, nearly 4 hours in and still not quite back to 100%)
If this were a 'normal' Lead Acid battery, I think the difference would have been a fair bit bigger.
What if you had a smaller charger? well, the Lithium would take all it could get (upto 50A per battery in the case of the RB100), and the lead acid would sit there for longer in bulk mode. But generally whilst the Lithium battery requires a charge it would use all that the charging system could give I would say, so if using say a Generator, the chances are you could run it for less time, which would make everyone happier I am sure.
So that kind of concludes this test
I think I will do another post just with my thoughts and possible conclusions for my own setup and which way I would go in terms of battery bank technology if starting fresh.
Damaging to what? the Battery or the Source (Alternator?)David, interesting results, I'm not surprised but most of your results.
I didn't know the RB100 had a maximum recommended charge current of 50 Amps.
So does this take us back to the B2B thread?
Without some form of charge current limit a Religion LiFePo4 battery could accept damaging charge current levels. True or False?
