Debs
Busy day yesterday, need to get back to work for a rest!
Morning spent at work testing some stuff that is going to be delivered tomorrow.
Bought a nearly new LPG cylinder from a guy on fleabay, turns out he is on High Street South, not far from where we are, so that was an easy collection. Cylinder is 65 litres and not very old, will probably end up on the Mercedes.
Philip had a failed rear wheel bearing to change, but decided to do the calipers as well while it was stripped down. The failed one came off OK, the half-shaft almost fell out of the hub, but the o/s one fought every millimetre of the way, mainly through rusting on the splines.
Both done now and he is back on the road. That's a £1000 job at a garage, I think it cost him under £250 for two new hub assemblies with sensors and two new calipers, plus a set of rear pads.
I started on getting the windows stripped out of the Mercedes, wasn't looking forward to it as they are bonded, but in the end we got three out without too much trouble. My right arm and shoulder are killing me now, three hours of pulling the bonding cutter through tough rubber.
Note that most of the rust is where the bonding has failed and water has got in. Where the bonding is good, the metalwork underneath is fine.
I've seen Ed China, on "Wheeler Dealers" use one of those bonding cutters, so I can well imagine just how sore you must be!
