Two general options for "split-charging" (using the alternator to charge your Lesiure Battery when driving) - a Relay system (such as a VSR) that just connects the Lesiure and Starter Battery together; or an intelligent Battery to Battery (B2B) Charger, similar to the Smart Mains Chargers but using DC-DC instead of AC-DC.
Both have their pros and cons (the main pro of the Relay is price compared to the B2B) and depending on the charge level of the battery, one option can be better than the other (PS. Talking Lead Acid Batteries here - Lithium is a whol different conversation).
The Relay method rarely (most likely never) will fully charge the Leisure Battery as the maximum voltage output of the typical Alternator is lower than the voltage needed to get the final 10% of so of charge into the battery. Add in Voltage losses on the cabling and the situation gets worse.
The B2B method limits the current going into the battery (depending on the size of the B2B) so on a heavily discharged battery this can be a real limitation on how fast you are recharging the battery.
CTEK make the D250SA 20A B2B Charger which is quite a neat product. Unique to CTEK, they also have a "Smart Pass" add-on. This changes the D250SA from a 20A Split-Charge system into a 100A capable Split-Charge system.
However, it does NOT make it a 100A B2B - the "Smart Pass" is really just a relay that the D250SA controls. So what it is is actually a combined B2B and Relay system which could potentially give you the best of both worlds - but at a price (~£600).
Rather than spending £600 to test the CTEK, I thought I would build my own version of their D250SA+SmartPass to see how effective it will be in reality (There are no widely promoted equivalents of the 250SA+SmartPass as CTEK have somehow managed to get a Patent on the concept).
This is my combined 30A B2B +120A Relay (actually a Victron Battery Combiner) - so should beat the CTEK 20A B2B + 100A Relay in performance as well.
B2B+VSR by David, on Flickr
The CTEK switches between the two using the battery voltage state. I am using a more precise Battery State of Charge to perform the switch.
How did it do?
This graph shows a fairly long journey from 10:30AM to 6PM with a lunch stop of around 30 minutes.
The Leisure Battery Bank was at around 57% SOC at the start of the journey. I was getting charge from both Alternator and Solar.
Because of the way the data is sampled, there are apparent dips and a few spikes on the black line - that is an effect of the fridge compressor in-rush and should be ignored.
This shows the battery was getting over 30A effective charge until the battery was at around 78% SOC, so more than the B2B could put out. However it hardly went over 50A for any length of time.
Also bear in mind that Lead Acid Batteries had recommended charge rates that are very rarely over C/4 (i.e. Maximum Charge Current of 25% or 25A into a 100Ah battery) and often only C/5 or even C/10 (10A per 100A of Battery), so you would have to have a very big and well discharged Battery Bank to be even close to the 100A Smart-Pass (or 120A Relay in my case).
The other aspect is the Alternator Performance - can your alternator deliver such high current for a continuous period?
So was it worth it?
The cost of my Combination B2B+Relay would be around £300 retail if if were the 30A B2B/MPPT plus the VSR add-on bits. That is a massive saving over the CTEK D250SA+ SmartPass for essentially the same features (the CTEK has a couple of extra small benefits, but so has mine).
But for the typical Motorhome with less than 250Ah of Lead Acid Batteries, I am not convinced the extra cost of the D250SA+SmartPass, or even the extra £60 or so of my setup to add the Relay to the B2B is worth it for the small additional benefit.
If I get hold of a CTEK D250SA+SmartPass, it would be interesting to repeat the test to see if there is anything that has I missed (but looking at the spec and the patent, I cannot see it).
I'll likely be deconstructing this and putting the B2B and Relay back in the 'lab' and refitting my original Victron 230A Relay (my batteries are unusual in that their full charge voltage can be as low as 14.1V, so I can get to a much higher SOC via the alternator and the Solar has a lot less to do to finish the job off)
For most Motorhomes and Campervans, I would recommend a B2B if the budget allows it.
How did it do?
So was it worth it?
