		Just goes to show how strong adhesive is if all air is expelled between two surfaces. Then sets and noway can air then reenter the jointlf you had two smooth and flat plates, say with a 12" square surface area. (not like Dave's square wire which is in fact round) Water placed between them. Then pressed together to expel most of the are and water. Seal the edges to stop air leaking back in. Now anchor each plate from the middle and try and pull them apart. That will prove how strong water is as a adhesive? The video is enough to put you of a good product. I hate the way advertising people sell products assuming the worlds population is stupid!
