Suncat
Hi all,
Forgive the pun, but I could do with a jump start (in direction!). I’ve recently bought a new horsebox conversation on a 2015 Citroen Relay chassis and I’m looking for the best solution (cost and ease of use) to keep the starter battery topped up as its not in daily use. And I thought that the Motorhome community would likely have solved this issue many times? The horsey community aren't too sure
My previous box was a lot older, so a straightforward battery isolator worked a treat, but I think that isolating the battery won’t do this van and all its electronics much good. Plus it’s a real fiddle to lock all the doors with no power! So I think my options are either:
A Solar trickle charger (Photonic Universe 20w perhaps?) – my battery is a 95Ah so I fear a 10W set up might not be powerful enough in the winter months? I’ve had a (good) quote to fully fit a roof mounted 60W system, but its £600 I don’t have yet sadly.
Or is there a type of trickle charger/controller which runs from a leisure battery only? Though the box doesn’t have a leisure battery system I do have a good one to hand, but all the systems I see seems to be set up to charge leisure firstly and only when they are full and there solar or mains input coming in, then charge the starter battery. Am I missing something? I don’t have a mains supply near the van’s parking, but can recharge a leisure battery overnight easily.
Any advice, links to resources to read or things to consider, all gratefully received!
Many thanks for reading
