		Now I had to take off a light fitting off in my Motorhome to access the cavity behind to do some wiring.  Nothing unusual about that really.
This is the 240V fitting in question
Now there is a decorative frosted glass plate in front of the fitting (this is the the one opposite)
Now I discovered two things about these glass fronts ....
1) They don't bounce very well if you let them slip through your hands
and;
2) The company that produced them for Autotrail went out of Business in 2011 and replacements are not available
I called Autotrail, who while very pleasant, were unable to help me.
So tried suppliers who may have old stock ...
I called Brownhills, who were unable to provide the parts but pointed me to Magnum Motorhomes
I called Magnum, who are located in Grimsby same as Autotrail and often buy clearance obsolete parts from Autotrail. They were unable to help.
So needed to work on an alternative solution as I couldn't just leave the fitting exposed!
Perspex to the Rescue!
Visited a local company that creates stuff in the stuff and came up with a suitable perspex that had the same thickness with a frosted front. Then they cut to size and curved
Next Step - paint the back in white same as the original glass was
Used my modelling kit for this - so Vallejo Acrylic paint sprayed on in the booth and then sprayed on a coat of floor finish for protection (sounds strange I know, but a floor finish rather than varnish works very well in an airbrush)
And comparing the Acrylic Front with the original Glass Front ...
These are the backs
And time to fit, along with a comparision
Glass, then Perspex
And same again with the light on (Glass first, then Perspex) ...
One thing I am still waiting to arrive are a pair of LED bulbs to fit in place of the standard ones. The heat from a normal 40W bulb could potentially cause a problem with the perspex due to heat so replacing with a 5W LED will eliminate that.
While waiting, I did a trial with a single LED Bulb I have with the Perspex shade and it looks just fine
The dimmer is a bit lower when I took this photo but looked good all the way from off to full.
Oh yes, the lights are on a dimmer so need to get dimmable 240V bulbs for the fitting.
Pleased with how this has turned out and that my butterfingers moment didn't turn into a major hassle, just a bit of an annoying temporary inconvenience.
It is a different shade of white to the original Shade which I expected due to the natural product and paint variance, and for that reason asked for a pair of shades to be made so I could have two matching replacements.
and;
These are the backs
Glass, then Perspex
