Is it actually worth doing though Dave rather than using the shunt to monitor totals and then a clamp meter to check specific bits of kit?
Interestingly, and it is something I should have realised if I thought about it, not only is this BMV monitoring the AMC B2B performance, but it is (as they read current both directions), it is also monitoring the AMT Battery Maintainer as this is fitted onto the AMC terminals for convenience.
This is a handy little bonus. So the graph below shows the Current in or out ("in" or +ve would be the B2B running; "out" or -ve would be the AMT operating), and the Voltage of both batteries:
(unfortunately, the custom 'widget' in VRM doesn't allow you to set the scales yet, so the scale for the two batteries are annoyingly different).
If I were to start the engine and the B2B turned on, then the current would go significantly +ve of course as power goes into the battery.
Because at this stage the Victron Cerbo GX and the VRM is not quite ready to use the BMV data when configured as a Energy Monitor, I have reset it back to being a Battery Monitor. The same data is available, but gets logged historically better (so you can see a cumulative log of power input from the B2B on a trip for example, or the working of the AMT as shown above) as well as a point-in-time snapshot which is what the Energy Monitor selection would give you).
As users of BMVs will know, the display is dominated by the Battery SOC (State of Charge), which is not applicable to this use, so that is a bit of a shame. One option, which is a bit clunky TBH, is to use a custom graph in the Node-Red option within Victron 'OS Large' Firmware. The following shows what a Node-Red Display could look like vs the native Victron Connect Battery Monitor Display:
I am sure it is possible to get something a bit prettier with Node-Red, and when I was trying out Home Assistant, that was certainly doable, so this is just a simple comparision of Non-Victron App vs Victron Connect.
I've noted A -D where the info is shown on each screen. The VictronConnect shows other irrelevant (for this function) info as well.
One thing to note... the SOC and Consumed Ah are as they are to allow AHs to be logged. When the SOC hits 100%, the Victron system stops adding in A/Ahs put into the battery so I have set it up to have an imaginary 2000Ah battery bank with perfect efficiency in order to just record the current flow in or out (the real Battery SOC is on a different BMV device). Eventually the Consumed AH would hit zero with extensive use of the B2B, but I will have logged that info and with the info from the MPPTs logged and the info from the AC Charging also logged, would be able to see on a trip what contribution each charging device made, which could be handy to know
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
All I would need to do is reset the SOC to be below 100% after each trip to relog the data.
I chose the 2000AH and 50% so I got a nice round "1000Ah" as my starting point and I can just ignore the leading 1 to see the real data (so right now I can see on that screenshot that since I set this up, I have put 1.6Ah INTO the Starter Battery. I would have known it was working before, but now I can see precisely how much it is doing
