The Flesh......Debs it look fab the pictures don’t do it justice, as I have seen it in the flesh.
£15 i used to charge for blasting and finish in 2 pac poly.Well I've had a good look at the spare wheel, and the "cones" are badly pitted. I could get it blasted and powder coated for £70 quid a go, or a new rim for about £60. So i've ordered four new rims from Oponeo and I will save the best rim on the van for the spare.
That’s cruel pointing out what you used to charge. Did your boss know about it.£15 i used to charge for blasting and finish in 2 pac poly.
I was the boss, Spraycraft LTDThat’s cruel pointing out what you used to charge. Did your boss know about it.![]()
I think it does make sense to not connect the output of a Power Supply to the output of the PV Panel - it could get very confused to what it is meant to be doing? (dunno for sure. never tried it.)Did you actually need the relay Deb? Would it not just lose any excess if both solar and mains fed together? I ask as on very good harvesting days I overfeed my controller but it just takes what it can handle
