Here you go big ears.I'd never buy a controller without a display.
Ha I say, HA!! in your dreams, so instead of buying one this that does all you buy two.That should keep Pudsey QT for a we while.![]()
No buy one but add the white box if you want, i dont have it and only a voltage unit on the dash, im not a battery current in out watcher.Ha I say, HA!! in your dreams, so instead of buying one this that does all you buy two.
If your need for solar is just providing a holding charge when parked up and not using the van, then a PWM controller would do the job. It is not as if they are no use at all, but just not as good or effective as an MPPT alternative.During the lockdown months I did a fair bit of work on local vans and snavarac. I encountered three of those dreadful fake mppt, blue pwm controllers often peddled on eBay that were boiling batteries each one had defaulted seemingly overnight to 24v so were significantly overcharging the leisure batteries.
I assume pwm must be of some use to someone because even Victron flog them to their I assume super knowledgeable fan boys but whenever I see any packaged in the format like those pictured above I want to see what’s inside to be certain it is what the manglefacturer claims it is!
