Is there any scope in mounting the cans on the side of the vehicle rather than the back? Could make things more restrictive in negotiating some roads I guess though?
Front mounted which might even out the weight distribution?
Don't want to do side because of the 'rip effect' of a mistake potentially could leave severe body damage and due to the tippy nature I am aiming for central mounting. I might be mistaken but IF I remember correctly UK does not permit front mounted, I know when I researched that option there was a good reason not to, but might have to recheck.Is there any scope in mounting the cans on the side of the vehicle rather than the back? Could make things more restrictive in negotiating some roads I guess though?
The only solid point is the chassis, a little over a foot back from the lip of the body. More weight and reduced departure angle.Tow bar mounted carrier? I see something under the back in your bushcraft picture but cant make out what it is.
Potential, yes, like itWould be thinking similar. Carry cans on back crossing europe, etc, as soon on rougher roads move to side or even front.
Bull bar mounted, doubt east of Europe anyone would care![]()
I do have 2 small external lockers but tools and spares will fill themDoes your van have any low external side lockers? I carry 4 x 5litre plastic cans in mine for petrol or diesel. During the lockdown I used one of my 25litre water drums for diesel, Caz would fill it when she filled the car, kept diesel heater running without moving the van.
This is good if your panel is flat. I like the bit about sealing the ply, something often forgotten when making composite panels.Customer service still exists, I got a reply from the fibreglass company;
don’t have a particular rule of thumb for load bearing 20ltrs to a fibreglass panel so you may have to over engineer it a bit to ensure it is strong enough. For this I would maybe bond in some plywood to the inside of the panel. To do this drill a peace of ply with a 10mm drill bit every 2" or so, then use freefix bonding paste to bond the plywood plate in place, the holes will allow excess paste to squeeze through and lock the plate into position. It is a good idea to chamfer the edges of the ply before installation so that you can then fibreglass over the plywood once the bonding paste has gone off. The chamfered edge allow ease of applying the fibreglass. Use two layers of 300g biaxial fibreglass cloth with epoxy when sheathing over. Then drill the mounting holes slightly larger than you need them once this is done fill the holes with an epoxy and colloidal silica mix and leave to cure before drilling the mounting holes again to the correct size. By doing this you will seal the plywood against potential water ingress around the bolts.
Just to be sure.........so your recommending a layer of aramid cloth and then bonding ply to that?This is good if your panel is flat. I like the bit about sealing the ply, something often forgotten when making composite panels.
For a curved panel I would still reinforce with aramid cloth of tape.
No, just heavily abrade the surface your going to laminate to and use about four layers of this https://www.easycomposites.co.uk/300g-22-twill-kevlar-cloth. It's slower to go off, but use epoxy resin to laminate it. Shop around I expect you'll find better prices. It will be seriously strong.Just to be sure.........so your recommending a layer of aramid cloth and then bonding ply to that?
I believe the aramid is to be used in conjunction with glass fibre.though I havn't direct experience of aramid, from talking to avant-garde motorsport people I thought aramid (=kevlar) was great for resisting puncture and abrasion, but use glass fibre for strength (or carbon-fibre if you're posh) . Ultimate was CF protected by a top layer of kevlar.
Either way, the shape will be more important. IMO you still cant just hang 2 jerrycans in the middle of a GRP panel, even in a monocoque, you've got to design a structure to carry this weight, esp off-road. E.g. add wood struts back the the chassis, using them as a former to glass over and create a box section.
Or just do it in steel, so that failure is some bending, rather than disintegration of your body structure...
