Pudsey Bear
Bloody unfair though.
I know nothing about Electric Scooters so the following may be totally wrong.....While away we went to a botanical garden and so Liz could enjoy it I took the scoot, the access was as usual pretty crap, but I carried on and the lowered kerb stopped it dead, the whole thing died so after a few times of switching it off it eventually came back to life, so we carried on and it seemed okay but after a while, it stopped dead again and then again so I looked at the battery gauge and it was in the red so I decided to go back the van, and it cut out so many times on the way and I had to remover and replace the battery each time, so I got off and folded it up and just dragged it, I chucked it in the van and didn't bother with it until today having decided to sell it, so I had it on charge for two days and I got it out of the van today in order to give it a bit of a clean as it has managed to get dirty, but I thought lets just give it a try on our road which is quite steep and very rough I went 0.3 miles up and then back down, it also tackled out short but steep drive, so I put it back in the van as is and popped it back on charge, now I don't know what to do.
Does any of the above mean anything?
Possibly I suppose but its a Li battery.I know nothing about Electric Scooters so the following may be totally wrong.....
I think yours is running a Lead Acid battery? Is that right? If so, The battery voltage will drop as the charge is used up and I would have thought the scooter - if it is a problem of the battery dying - would have got slower and slower rather than just stopping dead? and switching on and off a few times wouldn't have any effect. If the above is right, could the problem be bad connection/faulty control board/switch, etc rather than with the battery? maybe something that goes open-circuit when it gets hot and then when things cool a little, makes connection again (hence why off and on a few times may appear to fix it?)
In which case ignore the abovePossibly I suppose but its a Li battery.
the kerb was about 1-2'' high and it has very small wheels so I should have just stopped and lifted it up, I've managed others okay and I told them about it.Definitely something not right if you can get up dropped kerbs, I can ‘bounce’ mine up normal kerbs. Battery’s are frequently in poor condition on second hand mobility scooters which is why I said to allow for buying new battery’s in an earlier post.
I have a 12V charger for my scooter in the van but I found it seemed to take longer than using the 300W inverter and the mains charger. As mine takes a long time to recharge though it could be there is no difference.
I bought my 12V charger online from a shop that sells all sorts of mobility stuff but don’t recall the name. Should be plenty around if you have a Google.
No, too much messing about I'd rather just not bother, nowhere to park one anyway.Would you be better looking at cheap second hand but bigger mobility scooters and taking a trailer? Not ideal I know but you need something that will get you about
If someone NEEDS a Mobility Scooter but doesn't really want one, that looks like a good option.Good for the money
Veleco ZT63: retro electric mobility scooter in Italian style
With over 70 years of history, nothing can go wrong with ZT63 retro electric mobility scooter. Best choice in mobility scooter market. Feel the retro vibe!velobike.co.uk
