I don't know if it makes any difference, but it does seem to always be "secure to -ve pole", yes.
When I wanted a couple more monitors in my van, I got the BMV-700s and happy I did rather than SmartShunts.
Differences:
Smartshunt - Built-in Bluetooth.
BMV-700 - Need to add Dongle to use Bluetooth.
If you are a Venus OS (Cerbo/Venus/etc) user, then you can connect to either device using VE.Connect via VRM and bluetooth becomes unncessary. I find I connect to all the Bluetooth-enabled devices as well as the BMV-700s using the VRM method as more convenient.
Smartshunt - 2 inputs
BMV-700 - 1 input
So you can monitor either a second Voltage, or a temperature with the Smartshunt. The voltage bit could be handy, but the temp option if you have a Cerbo is less important (it has 4 temp inputs anyway). There is a BMV-702 that has two inputs.
Smartshunt - no relay
BMV-700 - relay
The programmable relay on the BMVs can be very useful. not that many people seem to use the feature, but they should.
Smartshunt - no head display
BMV-700 - physical display
It can be handy to have a display you can glance at without having to use your phone. In my own case, I have a BMV-712 with display visible, but the two BMV-700s are tucked away and the displays are not that important, however I can get info on them via the screen connected to the Cerbo.
Generally speaking, for a Primary standalone Monitor, I would go for the BMV-712 (full features so use in every way) first, followed by the Smartshunt.
The BMVs are awkward to configure and setup via the head display, so you want to be able to use VE.Connect (either by Bluetooth or VRM)
For a Venus OS system with connectivity, I wouldn't bother with the SmartShunt, but go BMV-700 or BMV-712 if you want a second input (the cost of the 702 is not far off the 712, and the 712 has bluetooth and a better relay anyway).
Remember you cannot have both a Bluetooth Dongle AND a VE.Direct cable connected, so if you are not sure if you will use Bluetooth or VE.Direct in the end, you would be best off with a device that has built-in BT so you keep your options open, which means a BMV-712 or Smartshunt
