The temperature sensor is an option on the smart shunt as far as I know, but I'm sure our friendly expert David will be along shortly to correct me
Does the Victron B2B not have a connection for a temperature sensor? I know on my Votronic B2B there is a connection ready but you had to buy the sensor separately
The Smart Shunt and the BMV-712 both have a temp probe option, and there is also the Victron SBS (Smart Battery Sense). All those devices can send Temp info using Victrons VE Smart Network using Bluetooth.
However, the Victron B2B, although being bluetooth enabled cannot participate in the VE Smart Network and has no temp sensor input or temp control as far as I know (bit of an oversight really IMO. Later versions may have added them but I don't think so).
What you can do with the Victron Smart-Tr B2B is use the remote control feature and use a little temp probe device to disable the charger when the temp goes below the pre-selected setting.
Get something like this -
https://amzn.to/3FJH5Sp - for £6 (less than 1/5th the price of the temp sensor cable for the BMV/Smartshunt or the SBS unit) and connect the relay up to the B2B Remote Control (connect K0 and K1 on temp board to H & L on B2B) and set the temp board up to open the relay (thereby turning off B2B) when under a certain temp. I use the same board to turn on a fan when temp goes above a set temperature.
There is a bit of a discussion on this thread -
https://motorhomebuilder.com/threads/bit-of-an-electrical-quandary.67049/ - where I posted a schemetic of how I controlled multiple chargers using the single temp sensor board.
