		Most Factory Motorhomes has 3-way (Gas/240V/12V) Fridges.  But if you want a more efficient Compressor Fridge  (which on my own tests are around 7 times more efficient on Electric) then you would need to remove the current Fridge, buy a new fridge and install it in its place.
Simple enough once you have adapted the space to suit (or managed to find a new one the same size), and also somehow managed to get the old fridge out the Motorhome and the new one inside (on a custom motorhome, the hab doors tand to be rather small so how you fit it in I am not sure? through the cab?)
If the 3-way in my Motorhome fails, I would be wanting to get an Compressor unit in its place, but would have the above issues to deal with.
However, maybe this approach is an idea?
 Don't replace but convert!
I wonder how hard it would be to take a compressor/cooling fin setup off a standard fridge and fit it as shown in that video?  I have no idea myself, but seems like it should be doable and if your fridge carcase is still fine, seems a good approach?
