Gas Combi Boilers, who's got one...???
StreetSleeper
You are correct, it would only be used for a short time. I was hoping to run it to a T piece; one going to the shower and the other going to the kitchen sink. The roof vent in the kitchen area would be open and so would the window, the shower room roof vent would be open as well.
Dinosawus
MOTOsapien
Does it take it's combustion air from outside?
Correct me if I'm wrong here AND I'm no gas fitter but fitted one years ago to a mobile library conversion of mine and it had a flu that incorporated outside air intake. I thought all boilers drew air from the outside as well as dissipating the bad combustion gases generated....???
Thats what I have always assumed yes, but we could be wrong. The inducted air is usually also associated with cooling the the flue too. Phil
I don't know your boiler and some things have improved over the years, but no harm in asking. Better than reading about the death of you and your family.
Thinking back, in terms of domestic boilers I don't recall any of them having any kind of vent to bring IN air from outside.
Absolutely all had pipework for the outlet but the inlet was just the air around them.
StreetSleeper
No, you can get both types, vented and non vented
Thinking back, in terms of domestic combi type boilers I don't recall any of them having any kind of vent to bring IN air from outside.
Most moder(ish) domestic combo type boilers use a balanced flue...
A sort of double skinned arrangement... Combustion air in and combustion exhaust out...
Various manufacturers make lpg versions on the same principle.
There are also lots of instantaneous gas water heaters out there that just use the surrounding air for combustion and vent combustion gases back into the room (no flue/flue less type)
Morco etc used to sell them for use in boats/caravans etc...
And lots of folks have fitted them without issues...
Though I personally wouldn't want anything that wasn't flued correctly... Especially in a small enclosed place.
We are talking combi boilers I thought, your right the early water heaters (Geyser) did indeed draw air from internal sources. Phil
Well, TBH I am talking combis as well.
The last boiler setup I did was around 2007 and was a Dutch Atmos Combi (chosen specifically as it accepted pre-heated water input so would work with the Solar DHW system). Just had a flue vented externally. No hole drilled in the wall for an inlet.
