Over the last few days I've been slowly working away at getting this heater fitted. After routing the fuel pipe and the electric cable for the pump my next job was to fit the pump. I have heard you can eliminate the clicking noise by suspending the pump off cable ties, it seems feasible and here we have a picture of my attempt at achieving suspending the pump.
This was then glued and screwed to the outer casing of the gas locker.
Exhaust is now all fitted and the pipe comes out just in front of the rear wheel arch.
Air filter and silencer, you can see why I had to repair the floor; a dab of underseal won't go amiss.
Control panel fitted to wall, had to cut the centre out of the plug socket as the hole was too large.
All that is now left is to wire up the live and the negative, put some diesel in but, first of all, I shall read the manual.
Rae
