@Squiffy After thinking about it some more, I think I've found a fault with my plan. Although I had not mentioned it, I was assuming that I would still be able to use the shower and sink water as normal while filling the large tank with hot water via recirculation. But when I was describing it to a friend (who is not even a DIY type), we came to the realization that the cold water pipes would become hot water pipes during the recirculation time. That means no cold water at that time -- which would probably be several hours.Tony your plan is definitely workable, I've done many a plumbing job on motorhomes and campervans and looking at your plan it is a workable solution to how you require it to work if that's what you require. The comments I've made were meant to be helpful obviously I mis understand your post. Phil
I've come up with a solution: an extra 3-way valve that allows cold water to be drawn from the other tank if needed -- it requires temporary disruption of the recycling mode, but I think it will work for my needs.This ofcourse is why the majority of posters on this tread have complained of lacking information. How you operate the taps is obviously dependent on how you open and close them. To most of us we would not even contemplate that many alternatives mainly because that many alternatives is a little ludicrous unless you are into mind bending puzzle solutions and I'm sure that in the general opinion of motorhome/campervan builders your pluming schematic although viable is totaly unwarranted unless as I previous stated you intend to go into the depths of the CongoPhil.
Your Bobil should be a similar setup to mine with the mixer valve 1 cup. Have you tried increasing tank temperature so it will add more cold water when you draw off? Bobil probably have info on it, I think my little bit of knowledge came from SureCal as it’s their gear I have fitted. Think it was quite a high percentage extra hot water if gave by mixing, mine would be around 80 degrees C at the tank I guess when heated from engine coolant and I think outlet temp at mixer valve may be set at 65c
doesn't matter if not drinking water. it can still be taken in when showering or just using. How many hot water tanks are used for drinking water? Apart from which, drinking infected water is not actually the main risk anyway.Thank you @Nabsim and @Sprinter 1 cup for sharing your experience. I definitely agree that dealing with microbes is a priority, and for that you need to either get all surfaces hot enough to kill them or clean regularly using bleach or some disinfectant. Of course, this also applies to cold water tanks if they are in an environment that gets them warm enough (eg, summer heat). As I wrote in my original post, this is not intended for drinking water.
Can you turn up the temperature of the heated water David? If so it may ease your situation as you would use less hot/more cold in the mix, would depend how close you are to getting your two showers now though.Mine is same.
The one thing I would be tempted to do occasionally is fit an small expansion tank to maybe double the 10L hot water capacity to have two nice hot showers in a row, but in truth the amount of times it would be noticeable it was done could count on fingers of one hand each year (only need aorund 30 mins to heat another shower full anyway).
I don't really ever run out of hot water. And I don't really bother with the routine of "get wet - water off - lather up - water on - rinse off" type of shower either. I just tend to shower like in the house. (bad practice I know).Can you turn up the temperature of the heated water David? If so it may ease your situation as you would use less hot/more cold in the mix, would depend how close you are to getting your two showers now though.
