So now need to put bolts though roof ! For unistrut full lenght
Sprinter has pre drilled holes yout push out grommets. what size bolts m10, m8 or m12 x 25mm ? 1
washers or plates for inside. 2a
What im fitting from off the rails.
2 x 100 w panels constantly fitted
Near side rail.. Awning that about 22 kg x 3meter = 3 brakets off it. So from the middle braket these will be 100mm x 100mm ally angle 135cm. Apart
Largest panel wise I will need to buy. It will go's over side door and from windscreen to kitchen skylight for winter use only. used least plus removaremovable. In summer
But would like 4 tie downs eyes in each corner so must take one end of a hammock the green dots on sketch with key.
So eye fittings ... back plate size for bolts on corners upto 250kg ? ..?2b
So must be proper!
So must be proper!
