Pocket drills what's wrong
So want a good job done.
So what went wrong first the screws? What are no2 not plus / Philips. Ok new bit needed as I have 200.
But the drilling, fitted to block to wood clamped and drilled but, this Can't be right???
The wood is 25mmx38mm and 4x2inches
Something's wrong!!!! Help please is needed.
TIA
Don't be tight, buy the proper stuff and you won't have problems. Whatever drill is supplied with that cheap arse kit it looks junk, the holes with the kreg drill are spot on every time.
When I got my Kreg stuff a few years ago I looked at the various copies and decided to just get the "real thing" as far as the Jig Set, Screw & Drill Bits and Pocket Screws are concerned.
I got this set - https://amzn.to/2Fassxv - although I will say it was a lot less money at the time I bought it!
I haven't really got much use from the stand that you put the wood in vertically, but the rest gets used.
And all worked flawlessly from day 1.
Well I started and cheap ones working but the drill bits justs wobbles and the 200 screws takes a sq no2 bit. Not Philips !!!
Should take a shelf or 5
ScoTTyBEEE
Yes and they don't show or push it has a specific tool bit!!! Lol
It comes with everything you need. I'm guessing your other one didn't. The only issue is sometimes that long bit is too long for tight spaces, but you can work with it, there is a shorter one available but I haven't been forced to buy it.
