Was thinking of using it for off grid wildcamping only so when not with other folk at sites.Oh please don't go down the gennie route Robert as so many people won't like you, including myself, because even the quietest ones make a far from acceptable amount of noise!
I remember a time when we were down in the New Forrest a chap shouted over from a caravan "I hope you don't intend to use that bloody thing, I'll bloody sabotage it if you do" pointing at my 10i Honda, I shouted back " Its been running for the last hour buddy, so go and bother somebody else" he swung round and stomped back into his caravan obviously embarrassed that he was pre complaining not realising that it was already running. The truth is these little Hondas are so quiet you can barely hear them from more than 20 feet away especially if they have a new exhaust or the exhaust is pointed away from others on the site. However I haven't used it personally for 5 years now though I still carry it incase of emergency. PhilOh please don't go down the gennie route Robert as so many people won't like you, including myself, because even the quietest ones make a far from acceptable amount of noise!
Robert, ref your brakes and hoses ... I am not a mechanic, but I would say is get them sorted by a old-school garage who make their own pipes and stuff as they need them rather than buying Mercedes parts to replace.I am considering something like this:
Clarke IG1200B 1.1kW Inverter Generator - Machine Mart - Machine Mart
www.machinemart.co.uk
Though I do not have a charger that is 30A and having seen the Mechanic today it looks like all the brakes and brake hoses need doing on the Merc and a spot of welding; so much of my budget for upgrades is going to be blown on getting the running gear in order, c'est la vie.
Mechanic though, who is a motorhome based and knowledgeable mechanic, said he thought i got the Merc for a good price nonetheless and besides the brakes issue it was pretty sound mechanically as far as he could tell.
Yes I always made up our own brake lines when I had the garage, not only was it cheaper for our customers, but a dam sight easier to fit as you could put a union on one end and feed the pipe through various tight areas then fit the opposing union on the other end. Manufacturers pipes were also in the main made of steel and hard to bend into shape ( If the were not already profiled) plus as soon as they were fitted they started to rust unless they were greased, the bundy pipe we used was rust proof (Copper alloy). The flexi pipes were a different matter ofcourse but much cheaper at Motor Factors than main agents. PhilRobert, ref your brakes and hoses ... I am not a mechanic, but I would say is get them sorted by a old-school garage who make their own pipes and stuff as they need them rather than buying Mercedes parts to replace.
When I got my LT (which is a Sprinter like yours under the skin), I took it to my garage to get serviced and checked over. They did the work and when they went out on a test drive and a brake pipe failed. they charged me an additional £5 for the pipe and fitting as they just knock them up as needed.
Pretty sure Sean makes his own pipes and that, he did on Sylvia the Talbot. Will probably see him again Monday and mention that to him and good points. When I got the Water Pump fitted to the Talbot I bought that myself and fitted it. Will ask him about parts cost but I doubt they will be Mercedes parts, probably some non-OEM parts I would think.Robert, ref your brakes and hoses ... I am not a mechanic, but I would say is get them sorted by a old-school garage who make their own pipes and stuff as they need them rather than buying Mercedes parts to replace.
Thought I would add a little extra comment on this thread ... bear with me here ....Any recommendations on Budget generators, ideally efficient, greater than 1KW output and quiet. ?
True, but then my son has a lawn mower with a honda four stroke engine which he has left outside year on year and has in four years never failed to start after a few pulls on the cord, we will see if it starts this year it looks a sight with rust and left over grass cuttings all over it, I have the exact same mower but is kept in a garden store and still looks like it was bought last season. I feel that although Briggs &Stratton do build good engines the engineering tolerances and electronics makes most small and large engines equated in performance and longevity. . PhilThought I would add a little extra comment on this thread ... bear with me here ....
I do not enjoy gardening. I have a petrol lawnmower and as soon as I can at the end of the season, I stop cutting the grass and the lawnmower gets abandoned in the garden until the next year (I sadly don't even put it under a cover!). Nice day here today so I thought time to cut the lawn
Went to get the mower, put some petrol in it, little bit of petrol direct under the ai-filter to 'pre-charge' and it started with about 4 pulls, cut out, but repeated the process twice more and now running smoothly within 5 minutes of going to get it. And this was after maybe 5 months of just being left outside.
Relevance of this? It is a Mower with a Briggs & Stratton Engine. And the above is the reason that when I bought a generator, I chose a Briggs & Stratton one
