Water heating for washing and showering.........
Older Gurna
Yeah, I just wanted to see how warm the water would get:- Was gonna fill 2 doz of 'em & then pump/pour into a little blow-up pool in the garden!! This was in the height of summer tho'!
Rodeo
Amazing how hot the water gets just in the garden hose when its trailing round the garden in the sun!
martyncc
heating water
I have 90ltr water tank on the roof ... up front .. used a roof box to house the tank .. let gravity do the work ... use a fixed connector ie hose lock ..let the tap pressure do the work .to fill the tank ...water gets quite warm on a sunny day
this is why a coil of black pipe works better; the water doesn't slosh about and the heat absorbing area is massive compared to the diameter of the pipe. also on a hot day even once the heated water has been pumped out,the cold going in has warmed by the time it's travelled 50 metres ! and the main water supply is on or under the floor
