Finally got round to finishing this for a Motorhomer Forum Member and thought I would post some info and a few pictures as it came out looking ok
Need to tidy up the control wire bit a little but that will be in version 2
I've made this setup before a few times before but this is the first one where the user does not have to do anything inside the box and can just plug in standard power leads without any messing around. The only fiddly bit is the Control Cable and that is just a lead with a 2 pin plug that pushes in so is not a big deal.
The WAS-201EC-UK is a AC Auto Selector box that takes two AC Inputs and automatically routes one of those Inputs to the Outlet socket.
The "UK" part is because it has the UK style 13A 3-pin Socket; The "EC" part means "External Control" - this is an option which makes the unit much more flexible for use with Fridges and Heaters; "201" is "2 Inputs, 1 output"; and "WAS" is "Wildebus Automatic Selector".
Top View - Just as you would think, you plug in the device you want to run
WAS-201EC by David, on Flickr
Side View
Two inputs, using the IEC style input.
When the Primary Input is live, that is the supply that is passed though to the Outlet Socket
When the Primary is off, the Alternate Input is the supply that is used - IF the External Control is enabled. If the External Control is off or disconnected, the Alternate Input is disconnected internally within the WAS-201.
How/why would you use one of these?
The main purpose would be if you wanted to use spare energy to drive a device like an 3-way Fridge, AC/Gas Water Heater (or even an Induction Hob or other sockets, but generally the multi-power devices are the key items with the EC model).
An example Scenario ...
You have an AES (Auto Energy Selection) Fridge. In auto mode it will use the following sources to power the fridge when available, selecting whichever is available in the following order: 1) DC (12V); 2) AC (240V); 3) Gas (LPG).,
If you are getting some good harvesting from your solar, It might be a good opportunity to use that power to drive your Fridge rather than the LPG and so save on gas (and money!).
In order to avoid drawing down the batteries too much if the sun clouds over or when it gets dark, you can simply connect the External Control to a remote switch to manually enable/disable the Alternate Input when you want, or ideally you would connect the External Control to a relay driven by an SOC Monitor such as a Victron BMV-712. You can then set the relay to turn off if the battery drops to a certain level. Around 80% could be a reasonable number but it really depends on your battery bank and how well the solar is working or if you expect to be fast charging (via driving or on EHU) soon so dropping the battery down a bit further is ok.
The Altenate Input would be from the Inverter and so when the External Control is on, that Inverter power will be used (assuming the Inverter is on, of course).
The Primary Input would be from your EHU, and when that supply is live, this is the one used always regardless of External Control condition. This means that when you plug into external mains, you will automatically have AC power to the Fridge (or whatever is plugged in) without having to mess around with moving plugs around (this is the "Automatic" part in the "Wildebus Automatic Selector" name)
Side View
