At last I have time today to post on fitting Mains hookup and charging system to my sons T5.
He intends to live in his van for a year while he completes his University coarse.
So we ordered all from Amazon ( Believe it or not it was cheaper or the same price as Screwfix).
First off was the removal of a weather plate in the scuttle behind the battery this entailed the lifting of the screen skirt through which the wipers protrude, don't remove the wipers this is not necessary just be brave and pull the top edge of the plastic skirt away from the screen on the far right remember to move the rubber trim along the bottom edge first. Pull the plastic skirt gently up and wedge a lump of wood to keep it raised, this allows access to the two torx set bolts that hold the back plate on. Remove the back plate and on the left hand side is a handy grommet where you can feed the charge cable through to the inside, to make life easy remove the lower passenger glovebox guard this is only a few screws and enables you to get at the cable on the otherside of the grommet.
From here we fed the cable under the rubber floor covering past the step and then fed under the rear floor covering across the back of the passenger seat and on to the drivers seat rear lower cover which in this case was the original plastic cover supplied by VW. This made a handy mounting for the VSR (Which had a digital read out which is great to show how much voltage was being supplied to the liesure battery).
From the VSR the cable continued on to the liesure battery, in this case I used 70amp cable through out with 50amp fuse at the cab battery and 50amp at the liesure battery as he was going to use the liesure battery to run an inverter for TV and charging his laptop plus Xbox
, so the liesure battery might get discharged down to the limit when he is off grid and could draw a fair ampage when the engine is running.
The VSR requires earthing which was incorporated with the diesel heater earth and attached to the seat base using one of the supplied self drill set bolts with the heater.
Then a hole was cut through the side of the van to take the electric hookup module and sealed then held down with stainless steel self tappers. Inside the van a short tail was fitted to the hookup through the insulation and side panel this was wired into a garage fuse box that incorporated the usual RSD, from here a twin plug socket was wired up and screwed to the side panel so that the purchased 20amp battery charger can be plugged in or his laptop charger and Xbox.
The last thing to do was replace the screen skirt and scuttle plate.
All in all it was a successful three days and now he's a happy bunny.
P.s. I forgot to mention that the main loom to the battery goes through a moulded grommet. To get the 70amp cable passed the scuttle plate it's necessary to drill a hole through the bottom of this grommet ( Carefully ) and feed the charge cable through, its difficult but can be done.
