A few comments .....
Controlling MPPT via RPi. This should be no problem. I do this on occasions, and via VE.Connect via the VRM option turned off the Load Output just this morning. I use a Cerbo GX not a Pi but that will make no difference.
I would disagree with you and would suspect the problem of not being able to do this is much more likely the DIY interface cable rather than using the RPi. I found the homemade cables too unreliable in use - they would disconnect randomly for no reason. It was not a physical issue as rebooting the GX device would find the devices again with no manual/physical intervention. This was on Cerbo, Venus and RPi units. I stick to proper Victron Cables for VE.Direct to USB connections although DIY VE.Direct-VE.Direct cables have never been a problem so often make my own for those.
I turned off the Load today as the van is off the driveway (need to make room for tree felling work) and wanted to minimise draw.
Using the Load output for the AMT is very handy - you can monitor it nicely and also via the App turn it off and on (usually
). I used to have mine connected that way but connected directly after I rearranged the electrics kit.
What I did then might be of interest? Connected the AMT up via two switches ... Routed the 0V on the AMT to -VE via a switch, and routed an additional connection on one of the +VEs on the AMT to SW1 on the AMT via a Switch.
So when the 0V switch is open, the AMT is forced off and will draw no power at all.
When the 0V switch is closed, the AMT will work as programmed
When the 0V switch AND the +VE switch are both closed, the AMT is in override mode and a higher rate trickle occurs.
These are manual switches so only accessible within the van but it does make it very easy to remotely control the AMT without having to mess with wiring.
