Holy Thread Resurrection as the saying goes!
So Battery #1 was done ages ago (last post was Jan 1st) and not used it for anything really for months and just been sitting in the battery box with the only thing attached an SOC Battery Monitor.
Despite not having anything done with it for must be a couple of months at least it is still sitting at 12.97V and a 100% SOC battery level. That is pretty remarkable and would point to a perfect battery I'll have to put a load on it and see what happens as it seem too good to be true
I setup the 2nd battery this weekend and connected a Victron SmartShunt on a RPi so I could keep an eye on it.
Just went out and turned off the charger as the battery was starting to get quite warm. Understandable really as I have been putting over 16V into it for the last 6 hours!
The battery is a 100Ah AGM 12V battery and so has a nominal capacity of 1200W. In the last day the monitor reads 1300W in. Even allowing for charging inefficiency that would be over 85% of the batteries capacity!
I'll put the charger on again in the morning and see what further charge it takes - Expecting the current to have dropped from the near-constant 16.2A (the lines are the wrong way round really - the voltage should be constant and the current dropping, not the other way round).
Will also be interesting to see what the voltage settles down to overnight.
