ricc
only an idiot would try to use a hammer drill to insert a screw. an impact driver is a totally different tool...... the hammer drill gives an impact along the axis of the drill bit to break up masonary under the drill tip. an impact driver gives a rotary impact to turn the screw....a bit like whacking the end of a spanner with a large hammer ..
to drill screws into metal you either use a pilot hole and normal pointed self tapping screws, or self drilling screws which have a drill like end pressed onto the end of the screw.
dont think id try to use an impact driver on plasterboard... id expect there to be a tendancy to wind the screws right through the plasterboard....a normal drill driver will allow some control over the amount of torque applied, have to get the balence between enough to get the screws into the metal and not too much to rip the heads through the surface ..
