Strange Victron Behavior
I have my habitation BMV 712 display so that I can see it without entering Murky.
Today it looked like it hadn't been charging. Firework damage?
No, looking at the 100-30 solar charge controller there was no charge!
Opening the app. It was claiming the temperature was -18 degrees.
I don't have a temperature sensor connected.
So, I disabled the temperature monitoring, and it started charging again.
Does anyone have an idea about this or a similar experience?
Mark
Mark
I have seen that quoted before but can't remember the cause.
Don't you have a Cerbo GX and are sharing centralised temp info via DDC?
No David, this is the older setup in Murky.
The only thing that has changed is that it was setup for lithium.
Not connected, but another annoyance is that the Daly BMS's go to sleep, and you have to put a load on the batteries to wake them up.
Ah.
I had a quick search on the Victron community and only thing I found was a post from someone where the temp on their MPPT was down at -18C and their IP22 Mains Charger was at -18C another time. There was no explanation posted though.
Daly BMSs going to sleep? pretty typical and a regular issue with a lot of Lithium Batteries. The majority of Batteries on the market seem to have that very irritating 'feature' and people like Will Prowse and Aussie Andy don't realise as they are playing around with the batteries all the time and never actually genuinely fully testing them :(
Have you up graded the software as I have .? Last weekend 3 blank days ! I dont have temperature on mine.
100 30.
But it started on june. 6th its just blank .....
zamirmewelld
Does anyone have an idea about this or a similar experience of 3uTools?
Mark
Yes,Are you using a Cerbo GX to share centralized temperature data via DDC?
ra8133
Strange Victron behavior often comes from incorrect settings, firmware bugs, wiring issues, or communication errors.. Checking firmware updates, connections, and configuration usually resolves the problem quickly.
Welcome to the forum, please read all of the posts before releasing your fingers, they can be dangerous. ;)
Mark
zubairseo31
Sometimes these kinds of Victron or battery monitoring issues happen when the system readings or sensor data are not updating correctly. I’ve seen similar cases where temperature or voltage values temporarily show incorrect readings until the monitoring service refreshes.
It can also help to double-check system parameters or run a quick digital verification portal guide to make sure the data being displayed is accurate before adjusting controller settings. Small validation steps often help identify whether it’s a sensor glitch or just a software display issue.
alikhanniaziniazi760
It sounds like the system may have stopped charging because the controller was reading incorrect temperature data. If the app shows a very low temperature like -18°C, the charging protection might activate automatically. Disabling the temperature monitoring could temporarily solve it, but checking the sensor settings or firmware might also help. Many modern systems depend on accurate monitoring data, similar to how digital platforms like the Ehsaas Program Online Registration rely on correct information to show status updates properly.
Users who viewed this discussion (Total:10)
