VXman
		Hi,
Came across this forum while searching the internet for answers to my issue. I haven't built my motorhome but thought maybe there are some experience people on here who may be able to help.
I have a motorhome with a 3 way Thetford fridge. (N4000 series) It has auto selection and only uses 12V when the engine is running. It uses a Schaudt ebl119 for electrical charging/distribution.
On a recent trip it started misbehaving. I noticed one day that the leisure batteries voltages started tumbling when I was driving (they would normally be charging when the engine is running) The fridge started flashing a red error light. If I switched the fridge off the leisure batteries would recover. What is odd is that the Leisure battery would not normally be used when the engine is running - it should be powered by the engine battery/alternator.
There is a 20 amp fridge fuse (according to the vehicle manual) by the leisure battery which melted. (I must admit I do not understand why there is a fridge fuse on the leisure battery when it should in practice never use the leisure battery as a power source) There is also a 20amp fuse by the engine battery which is also labelled as a fridge fuse. This one was ok. There is a 20 amp fridge fuse on the EBL which is also ok but doesn't seem to do anything anyway as I have removed it and nothing is effected.
The problem was intermittent initially. Sometimes it seem to happen when we stopped for a short break and then when the engine was restarted the problem started. However, later on it might be ok for 30 minutes or so of driving and then would start failing. Towards the end it seemed to be working but then I smelt burning from the 20A fridge fuse by the leisure battery and it had begun to melt again.
So a very confusing problem that I am struggling to understand. This had been working fine for over a year since the fridge was fitted. Fridge is fine on Gas and 240 volt.
Is it a fridge issue or a electrical issue and if the latter what could it be?
Would appreciate any ideas.
		 Phil.
 Phil.
