philgb
I cant get my head around my latest self build 12v electricary and could do with a bit of this will work or that wont work dialog.
Have 2x110 amp leasure batteries. 1x 100 watt solar panel. 1 waeco 12v fridge 48amp. Plus 4amp tv. Led lighting, water pump.
Swmbo wants the fridge running 24/7 plus a couple of hours tv. Even though we only do 4/5 days wilding at a time and move the motor regularly.
Not sure if to keep the leasure batteries seperate, charging 1 (tv etc) off split charger. The other (fridge) off the solar panel or to connect both batteries together connected to both split charger and solar controller?
The solar controller can charge 2 batteries at the same time. Would it be best to connect the solar to the lessure battery(s) plus van battery or to the 2 seperate leasure batteries.
Hav'nt purchased the split charge unit yet, what size do you need to charge 2 leasure batteries?
Sorry if this sounds confusing as I am ha ha confused. So any dialog that could give me a eureka moment would be appreciated
