I would be very nervous about relying on a non-mechanical adhesion, especially on a glass panel with the aluminium frame.  Picture that flying off and going into someones windscreen behind you.  Could spoil their day somewhat!
Doesn't matter how good the glue is, you are still very often sticking it to a layer of paint just microns thick with an unknown adhesion quality to the surface below.
I
have used non-mechanical fixings on a pair of semi-flexible solar panels.
This is the underside of one of the panels:
Panel Underneath by
David, on Flickr
3M VHB Tape used every 25cm or so along the lengths of the panel; the roof is an unpainted (self-coloured) fibreglass roof and I checked with the manufacturer of the roof AND the manufacturer of the Solar Panels that this tape would be suitable on their product; and finally there are strips across the front to stop airflow going underneath to prevent lift and/or flex at speed  (the panel also has a rigid fibreglass backing and does not expand/contract).
As soon as the tape backing tape was pulled off and that panel made contact with the roof it was stuck firmly and could not be shifted a millmetre - and that tape still needs 24-48 hours for full bonding strength!
			Ouch to both hopefully it is still attached, mine will be bolted to a rack I have made and the rack bolted to the roof.
May your bones knit quickly.
That is the approach I took - fit tracking to the Roof that in my case is both stuck down with 3M VHB AND mechanically bolted down;  and then each panel (have 4 glass panels) is mechanically attached to the tracking with brackets.
Not having the panels glued down makes it very easy to change/adjust anything on a panel if you want to.
			Mine our connected in two pairs, during our Dutch adventure I heard percussion on the roof whilst driving at high speed.  I think I've lost a panel now
  can't investigate for a while as I managed to brake my leg whilst out there.
Oops on both
I think if you have 4 panels on the roof, a combination of Series & Parallel above is the best option on a 12V Battery System
.  Gets you the extra voltage for performance and covers you against shading well.
With 2 or 3 panels, it becomes a choice of either Series OR Parallel - and typically Series will optimize the harvesting performance if having to choose between the two ways.
