		I'm looking at fitting solar panels to the roof of our van. The van is a Mercedes 814 so plenty of space!
I will be using a compressor fridge, & blown air heating which I think will draw the most! Then we'll have 20 led light scattered around? The power to the cooker ( lighting it ) the power to the toilet, and the water pump also a 12volt phone charger socket . Theses will all run form the LB which will have a split charger & mains charging when 240v is available.
Our VB is running 24v via 2x 12v batteries I intend to only use 12v in the habitation side and still have 2x 120Ah batteries.
I hope I've given enough info here? To work out the amps I'd need.
Secondly. What's the difference in the different solar panels available and controllers ?
Thanks Darren..
Thanks Darren..
