PeteS
Ive been looking to find away to stop a Victron Orion Tr B2B charger charging LiFePO4 batteries below 0C and I think Ive finally settled on a method.
Ive been playing with a W1209 Digital Thermostat to control the B2B via its high input. To my delight the settings are stored in non-volatile memory when the unit is switched off. In other words it remembers its settings so on next power on it just carries on.
This means it can be powered by a D+ signal and the relay contacts can pass the D+ to the H input on the B2B thus enabling it to charge.
The current consumption with the relay on is around 75mA which is higher than specified and whist not significant if in daily use, in storage over winter it could be significant if coupled with an alarm and other kit.
Seems to work a treat so far, I have it set to 5C, it would have stopped charging last night!
