Hi Whitevanwoman, now this is bit of a longshot but is there any chance of putting some sort of dye ( food colouring or similar ) arround the suspect area & seeing if the water that comes in contains the colour too ? maybe not that easy in practice though
From experence I would say light clusters do tend to leak a bit as they age, & for what it's worth I have just had to seal up one of the welded seams on the roof of my works transit, I could not see or feel where the leak was coming from on the outside & despite using plenty of silicone sealent on the outside it wasn't untill I ran a bead of sclicone on the inside of the van too that I stopped the leak ( where the leak was coming in on the inside of the roof was easy to spot ) good luck with it though leaks sure do drive you nuts !!!
As for the self tapping screws maybe a friend will have a drill you could borrow or even a local tool hire shop will let you hire one for half a day or a day ? it would deffo be worth using a powerd screwdriver/drill , I couldn't think of how hard it would be to do them by hand :scared:
The food colouring idea might be worth a go once I've got it dried out a bit. I'm going to try to get some photos tomorrow to explain why it's so difficult to see the source from the inside. Even if I can't see fishing around with kitchen roll should show up any colour.
The Capt Tolleys has worked really well on 2 other leaks (one around a whirly gig roof vent which I couldn't get at with the Sikaflex nozzle) and one around the seal on plastic tap on a water container so I'm hoping that, with the amount I've put on today, that it will at least work long enough for it to dry out a bit so that I can then jet wash it.
There's another leak too, diagonally opposite in the front corner of the cab on the drivers side, just where the cab roof meets the windscreen, right in the front corner where the sunvisor hinge is. I'm pretty sure it's probably the windscreen seal but as the windscreen has got a crack in it and I need to phone Autoglass to get it sorted, I'm going to wait till I've done that as I may need a new windscreen. Just to be on the safe side though in the meantime, I've painted Capt Tolleys around the windscreen seal and along all seams, joins etc within about 3 foot of it.
It's a good job I love my van! And that I've spent too much money on repairs now to consider getting rid of it!
I've had plenty of blisters over the years with all the DIY I've done at home and on other vehicles (am enthusiastic though not hugely skilled) but it's so time consuming doing it all by hand too, that I think I probably will buy a power screwdriver but one that is more than 4.8v like the last one I had. I don't mind spending up to about £30 on one if it's going to be worth it but if it's only going to last a year then I'll just get the cheapest one I can find and consider it "disposable".
I must admit I've had more than my money's worth out of my Black and Decker drill - I think it was about £30 in 1995 (I remember getting it out of Littlewoods catalogue and paying it off weekly
) so I know that with tools it is very much a case of you get what you pay for. I've found that the cheap screwdriver heads from poundshops etc just bend or break as do cheap drill bits, cheap pliers, cheap spanners etc, but sometimes you just have to buy what you can afford and accept the limitations. But the 4.8v power screwdriver I used to have was pretty much a waste of money.
