coolasluck
Hi folks probably a daft question but can i earth my 12 volt leisure batteries system to the same chasis earth that is shared with my 24 volt engines batteries?
All negative connections should be connected to chassis and the positive terminals will go to the respective 12 or 24 volt chargers and loads.Well its hard to know what to believe lol:danger:
I have a large bank of trojan batteries set up for 12 volt and my starters next to them which are 24 volt.
My durite charger is a 24 to 12 volt converter .
I would have personally thought that an earth is an earth .
As the 24 volt earthing point for the engines batteries is so close by i fealt it to be prudent to earth the 12volt to the very same point that the 24 volt setup is earthed at.The earth would run to my bm2 battery monitors shunt.
An earth is an earth mate, take no notice of these wallies.![]()
Very dangerous as 24v electrons can outjump 12v electrons causing a massive implosion probably leaving a new black hole.
And on what probability scale has this been tested on ??
